Where is a good spot to place jack stands under my car?
Old Dec 5, 2006 | 05:28 PM
Riko's Avatar
Default Where is a good spot to place jack stands under my car?
i dont want to crack anything or have the car slip off.
Old Dec 5, 2006 | 05:32 PM
Papachristou's Avatar
Default RE: Where is a good spot to place jack stands under my car?
I posted this on the 'zine a few weeks ago before i put my rear rotors on and i got a bunch of smartass answers like u should jack the car up and put stands next to the jack.. it will bend the rail under the car... and i also got answers like u shouldnt be working on ur car if u cant figure out how to jack it up but anyhow
in the back i found two piece of subframe or something just forward of the rear axles.. it was safe for me! lemme know what u find up front cause im doing front brakes in a few weeks!
Old Dec 5, 2006 | 05:44 PM
BaconBait's Avatar
ORIGINAL: Riko
What year?
ORIGINAL: Papachristou
Just did some coilovers on a B6. In the rear you can use a jack next to rail at the stock jack point. We put the jack stands on the subframe below the diff. On the front, put the jack on the inside of the rail and as par back as possible without it hitting any plastic. Place the jack stand towards the front of the car. It's really tight. We ended up using the stock screw jack to lift it because it's so tight.
Always use jack stands and engage the emergency brake
Old Dec 5, 2006 | 06:26 PM
Bondga's Avatar
use the stock jackpoints, and on top of your jackstand place a piece of 2x4 to maximise surface area and minimize damage. that will also help with stability. Make sure you chock your wheels that stay on the ground
Old Dec 5, 2006 | 11:12 PM
Slowb5's Avatar
papa got a hottie on that vehicle in that avatar. nice work. look under teh car, there will be points near the wheels that you can tell are meant for jacks...not too hard, jus gotta get a lil diry.
Old Dec 6, 2006 | 12:48 AM
Cruiserhead's Avatar
this is a nice writeup w/ pics.
http://forums.audiworld.com/a4/msgs/1591159.phtml
Old Dec 8, 2006 | 08:53 PM
Riko's Avatar
My car is a 2001 a4 1.8T I plan on taking all 4 wheels off so i cant have them touch the ground.
uglyfatjoe
Oct 14, 2008 08:56 AM
Red_sapphire89
Mar 4, 2008 08:25 PM
TheJazz7
Jul 18, 2007 10:02 PM
smtcapecod
Apr 7, 2007 02:48 AM
mjvss21
Dec 3, 2005 10:33 PM
