Where should the RPMs be?
Old Sep 7, 2007 | 05:53 PM
  #21
kextyn's Avatar
Default RE: Where should the RPMs be?
Umm...engine size really has nothing to do with it. Your RPM at a given speed is dependent on the transmission, differentials and wheels. But normally you'll see different diffs or tranny gear ratios on a bigger engine in the same car to take advantage of the power curve.
Old Sep 7, 2007 | 06:24 PM
  #22
sdboarder84's Avatar
To clarify; engine size does have something to do with it. The engine determines the amount of power produced and the cars are geared accordingly. Bigger engine makes more torque down low so they are geared to cruise at lower RPMs. Moral of the story is yes you should be cruising at over 3000 RPMs in your Audi. Its engine makes its power at higher RPMs primarilyaround 3000 because of the turbo thus your car is geared to cruise at those RPMs to maximize the ease of freeway driving and maintaing higher speeds.
bbeach
Feb 21, 2012 06:25 PM
murdox
Sep 13, 2011 12:49 AM
nexusgroove
May 8, 2006 01:49 PM
yongk1
Nov 18, 2005 08:34 PM
Dudek12
May 4, 2005 10:31 PM
