Whining sound from Steering wheel
Old Feb 23, 2005 | 02:44 AM
apg96's Avatar
Default Whining sound from Steering wheel
I have a whining sound coming from my steering whell when i turn it. I checked the brake fluid already and it was at max level.
Old Feb 23, 2005 | 02:46 AM
Karl's Avatar
Default RE: Whining sound from Steering wheel
holy crap... did you check the powersteering fluid....
Old Feb 23, 2005 | 02:48 AM
apg96's Avatar
where is that located in the engine compartment? What is the lid cover?
Old Feb 23, 2005 | 02:49 AM
Karl's Avatar
check your Manual... and make sure you use the proper fluid
Old Feb 23, 2005 | 03:11 AM
apg96's Avatar
what would u use Pentosin 11S, and if i change it do i need to bleed it or anything like that? How do i drain the fluid?
Old Feb 23, 2005 | 04:11 AM
Karl's Avatar
dont quote me on this but i believe you should be able to just top it off.... and you shouldnt need to drain it but if you do you could probably use a turkey baster I cant remember what type of fluid my manual says to use but it should be in yours if you have it. if you dont i can look it up in my manual. Best of luck to you
Old Feb 23, 2005 | 09:50 AM
david9999's Avatar
I don't have a photo. The PS fluid reservior is right behind the driver's side headlight next to the windshield washer fluid reservoir. On my car it has a green cap, with warnings about only using correct mineral fluid.
If you change it, there are complicated ways of draining the steering rack. I just use a turkey baster, suck out what fluid I can from the reservoir and replace with Pentosin 11S.
Take the car for a drive for a week and at your convenience, repeat the procedure. It wont get all of it, but you should get a whole shot of fresh fluid in there.
BTW, invest 15 dollars in your car by buying a Haynes manual for the A4, so that at least you can learn how to perform basic car maintenance. This is a much better investment in helping your car run better and faster, than the air intake you are obsessing about a few threads down.
If it just squeals when you turn the wheel fully to the right or left, this is normal and indicates that you are putting a lot of strain on the system. All cars (with ower steering do this). Stop turnig your wheel fully.
Old Feb 23, 2005 | 11:03 AM
Jestnomen's Avatar
6th Gear
On the underside of the power steering reservoir there are two lines. I disconnected both of them and drained out all fluid that I could from the tank and the rubber lines. It requires no bleeding, you just fill the reservoir with fresh pentosin 11s
Old Feb 24, 2005 | 12:14 AM
apg96's Avatar
ORIGINAL: david9999
i have one of those already. But i couldn't find anything about replacing the fluid how ever i did find where it was
Old Feb 24, 2005 | 01:37 AM
apg96's Avatar
I just checked the level of the fluid and i didn't see any markings on it. Is it supposed to be all the way to the top. Mine has like three inches down until the fluid level.
