white stuff on oil cap?
Old Jan 10, 2006 | 03:02 PM
sandman's Avatar
Default white stuff on oil cap?
i did some research and found out that this is normal in cold rainy areas when doing short trips not allowing the car to completley warm up. well where i live its been pouring and yesterday i did a couple short trips, not allowing the engine to completley warm. at first i was worried and i will be keeping an eye on this but i am really just curious if anyone else has experienced this?
Old Jan 10, 2006 | 03:07 PM
ecartoys's Avatar
Default RE: white stuff on oil cap?
As long as the oil on the dip stick is clean and free of milky concoction you have nothing to worry about. A little condensation is normal for people who don't quite heat up the car in high moisture locale.
eCarToys
Old Jan 10, 2006 | 03:10 PM
techbod's Avatar
that's normal due to lack of long drive out, white/gray is a pointer so take it for a decent run once a week, "yellow/mayonnaise is a problem" because water/coolant is in the equation
sandman's Avatar
ORIGINAL: ecartoys
eCarToys
yea the dip stick is good. thanks for the reassurance
Old Jan 10, 2006 | 03:33 PM
Kellya4's Avatar
Our shop van used to get started, driven to the back of the shop and turned off. Then we would start it drive to the dront and do this alot. When i looked at the dipstick, there was some water in the oil from the engine not getting warm enough. Once we drove it on the freeway for awhile, it cleared out.
Old Jan 11, 2006 | 10:05 PM
MadIce's Avatar
Ya I have the same problem also. I'm hoping its just the condensation & the fact that I do have a good amount of short trips. But also when I pulled the head covers there was a good amount of it and had the white-yellow tint. Hopfully I don't have a bad head gasket... here's my thread:
https://www.audiforums.com/m_187665/.../tm.htm#187665
yuriy
Nov 15, 2009 09:56 AM
A4 Effort
Apr 9, 2008 08:56 PM
mandeepkang
Dec 22, 2006 01:36 AM
