Why does Audi purposely the top rear light?
Old Jan 19, 2006 | 08:35 PM
H2JMC's Avatar
Default Why does Audi purposely the top rear light?
I have an 01 a4
Does anyone know why the top of the four right rear light is blocked off?
I thought for the longest time that I had a blown light, but I just too the encasement out and discovered that even though there is a socket for a light, there arent any bulbs that can fit through the encasement.
I called audi and the best answer they gave me was that it was a german thing.
Should I not just file away the plastic that's in the way?
Old Jan 19, 2006 | 08:39 PM
ryanmcell's Avatar
Default RE: Why does Audi purposely the top rear light?
rear fog light on the upper left. u can put a bulb in the upper right to even it out... or just leave them off is all i do
Old Jan 19, 2006 | 08:40 PM
ryanmcell's Avatar
ah as for making it fit i believe u just have to trim off the plastic slightly.
Old Jan 19, 2006 | 08:46 PM
onepoint8tee's Avatar
Do a search "rear fog light".. You should get a better answer than what audi gave you. Its basicaly so that people behind you know its not your brake light, and it penetrates the fog so people can see you in front of them... Its brighter than your tail lights (not brake lights).
Old Jan 19, 2006 | 09:02 PM
H2JMC's Avatar
thanks a lot... i appreciate the better answer
if i do scrape off some plastic to put another light in, what type of light should it be? I want it to be as bright as the one on the left but that incasing is harder to get too so i didnt bother with it.
Old Jan 19, 2006 | 09:46 PM
haveaseat's Avatar
Member
ive done it already....just get a dremel and cut out till a bulb fits...if i remember correctly its 1157a i think thats the bulb number...just look at what bulb u got in the left side and get the same bulb otr buy a pak of 2 and replace both like what i did....hardest part of this is the clean up of all the little plastic bits i dremeled out lol....but it makes for a nice look when u put on the rear fogs which i do gotta say i dont do often only when needed...but i havent had any problems since doing this so good luck
Eveyck
Jun 6, 2013 05:24 PM
protivakid
Feb 1, 2011 10:11 PM
2004-audi-a4-1.8t-amb
Sep 16, 2010 10:01 AM
Kraysaw
Dec 20, 2007 01:58 PM
SL
May 26, 2006 12:47 AM
