Why replace DV with a stronger spring rate???
Old May 11, 2007 | 09:32 AM
fahquad's Avatar
Default RE: Why replace DV with stronger spring rate???
Even if installed "correct" air tries to escape somewhere, and under that pressure it would find its way out.
However, a large percentage of us run the valve in reverse; some say it holds boost "gooder" and it makes a louder BOV sound (Forge 007). In that case, with the boost pressure pushing directly against it instead of at the side, you need to adjust spring rates or those of us pushing >20 will leak.
[align=left] [/align]
Old May 11, 2007 | 11:03 AM
kchao2000's Avatar
Sorry, my reply is nothing to do with this subject. Fahquad, I emailed you a question regarding your body kit. Did you receive it? Thanks.
Old May 11, 2007 | 01:12 PM
Aznpulse's Avatar
Member
Would it be better to stick with the stock DV when running a unchipped car? or is it better to run it with a performance DV? Right now i'm running my car with the Baily's.
Old May 11, 2007 | 01:45 PM
fahquad's Avatar
ORIGINAL: kchao2000
I never check PM's 'cause I'm on like 5 audi forums.... lol I just checked and although I had a bunch, nothing was there from you. Resend or hit me up email at lee.wasson@cookmedical.com
There is no body kit on my car. Sides are S4 door blades and front is stock; I cut out the lowest center cross piece and all the support pieces in the middle (to give more exposure to FMIC), and then molded Zender lips to the bottom. Then I did custom mesh for all grilles. So I guess you can say it can't be bought anywhere. But it doesn't look like that now as I keep messing with it to get the lines to match up a little more and not look so "body kit" like. Adding a splitter this summer, too, but molding it in instead of slapping it on and leaving unpainted.
readimag
Aug 7, 2008 02:45 AM
speedys4
Jun 28, 2008 11:36 AM
Trey25
May 24, 2006 05:38 PM
BlueLord
Feb 21, 2005 05:02 PM
