Will Rims make my car.....
Old Feb 2, 2007 | 12:45 AM
Amze's Avatar
Default Will Rims make my car.....
I'm just curious about rims, if I go with 18's instead of the stock 17's I currently have on my car will it make my car slower? And if so by how much, cause I would love the look of 18's but not if its gonna **** up gas mileage, speed or just screw with my mileage in general.
Thanks in advance,
Amze
Old Feb 2, 2007 | 12:48 AM
Lazer Viking's Avatar
Default RE: Will Rims make my car.....
not noticibly
Old Feb 2, 2007 | 12:50 AM
Ford2Audi6's Avatar
One inch is not that much. Some of the ultra sports I think came with 18's with the same brakes with the same engine so it wont be noticable.
Old Feb 2, 2007 | 12:55 AM
widgget's Avatar
Ideally you want to keep the Outter Diameter the same as your current setup in order to keep the speedo on key. being slightly larger will give you more high end, but i don't think it will be noticeable unless you make a big jump in size. check this out -----> http://www.miata.net/garage/tirecalc.html
Old Feb 2, 2007 | 12:58 AM
widgget's Avatar
Copy and paste the link into a browser, they seem to be perventing redirects.
Old Feb 2, 2007 | 01:00 AM
akielb's Avatar
I prefer this one here
http://www.discounttiredirect.com/di...TireMathNS.jsp
Old Feb 2, 2007 | 01:02 AM
xAUDIx's Avatar
Anyone know the specs for that site on a stock 98 a4 2.8
Old Feb 2, 2007 | 01:07 AM
akielb's Avatar
what do you mean specs? your tire size?
Old Feb 2, 2007 | 01:22 AM
Amze's Avatar
So, as long as the width is close to identical I should be A, OK?
Old Feb 2, 2007 | 01:35 AM
Sp33d07's Avatar
i upgraded from stock 15's to 18s, you gain some then loose some, the rims i got were actually lighter then my stock rims, it also had kuhmo tires which stick to the road really nice, only thing is that the bumps are more noticable, other wise have no complaint, i think that could be fixed with a more expensive tire but it doesnt bother me. if you got the cash go for it but you are gonna need suspension too because your car will look like a 4wheeler
