Will an uncut a6 key work in an a4?
Old Jan 19, 2005 | 01:21 PM
CRAZYHAWK's Avatar
Default RE: Will an uncut a6 key work in an a4?
Autozone now makes fob keys.
Old Jan 19, 2005 | 01:33 PM
Jestnomen's Avatar
6th Gear
You mean they actually stock the key, or they have the ability to cut them?
Old Jan 19, 2005 | 06:54 PM
jason745's Avatar
ORIGINAL: Jestnomen
they stock the keys and remotes, however they don't carry the audi keys.
My dad works there and I already talked to the distributor.
Old Jan 19, 2005 | 07:18 PM
Jestnomen's Avatar
6th Gear
That's strange, doesn't seem like an item they would carry.
Old Jan 19, 2005 | 09:17 PM
jason745's Avatar
yeah they just started doing it. I think they are testing it to see the response.
http://autozone.com/servlet/UiBroker...ters=%7C%7Eyes
Hope that link works for you.
Fine print:
REMOTES ARE AVAILABLE FROM $49.99 TO $199.99 REPLACEMENT REMOTE CONTROLS ARE NOW AVAILABLE FOR FACTORY KEYLESS ENTRY AND AFTERMARKET ALARM SYSTEMS. BEFORE YOU CALL YOU MUST HAVE THE FOLLOWING: 1. CUSTOMER PRESENT. 2. CUSTOMERS OLD REMOTE IN HAND AND FCC ID# FROM BACK OF REMOTE READ AND READY TO REPEAT TO CSR. 3. IF NO REMOTE IS PRESENT; YEAR, MAKE AND MODEL OF VEHICLE OR BRAND NAME AND MODEL OF AFTERMARKET SYSTEM. TO GET PRICE FOR PART CALL REMOTES UNLIMITED AT 866-728-8696 (866-7AUTOZONE) ******* IMPORTANT ******* PART NUMBER WILL BE GIVEN BY CSR ONLY WHEN ORDER IS BEING PLACED. ENTER PART NUMBER INTO WITT TO CHECK AVAILBILITY AND COMPLETE THE VDP ORDER
I did however find this site: http://www.keylessride.com/default.asp
for my remote & key it is $83.
Old Jan 19, 2005 | 09:22 PM
Jestnomen's Avatar
6th Gear
First link doesn't work.
Old Jan 27, 2005 | 09:04 PM
jason745's Avatar
Works perfect Jestnomen!
I followed these instructions:
1. Take a spare key and insert it into the ignition. Turn it one click forward.
2. Roll down your window just in case. Step outside the car, and lock the car with a second key.
2b. Take key out of lock (it wouldn't program with the key in the lock for some reason)
3. With your second key fob press the unlock button. The lights should flash.
4. Now lock the car with the key fob, and then unlock it.
5. Remove the key from the lock and the key from the ignition, and try it's function.
I couldn't get an uncut key, so I bought a a6 remote with a cut ke ($15) and then just a blank blade ($20) (the dealer cut it for $10 bucks), and followed these instructions to swap blades:
Swapping keyblades…
The keyblade is held in place with a small roll pin, flip out the keyblade halfway and you'll see it. To separate the keyblade from the device, just hammer out the pin with an appropriately sized punch or nail. After that, you should be able to pull the keyblade away from the device. If you can remove the keyblade properly, you can figure out how to reinstall it onto a new remote on your own. When reinstalling, just make sure the side of the keyblade with the logo “Huf†is facing the opposite side of the panic button when flipped outward, or else the roll pin would not go in
Old Jan 27, 2005 | 09:33 PM
  #18
Jestnomen's Avatar
6th Gear
excellent, glad it worked out for you.
Old Jan 27, 2005 | 10:26 PM
  #19
David_K's Avatar
autozone stocks almost nothing for any german cars.
mmhyson
Jun 8, 2009 07:19 PM
Timewise
May 22, 2008 04:11 PM
CTDriver
Apr 9, 2008 03:14 PM
Timewise
Jan 23, 2008 01:48 PM
fastfreddy
9
Apr 24, 2006 10:19 PM
