will it work
Old Nov 11, 2007 | 09:57 PM
powersmokin's Avatar
Default will it work
will the tranny from a 96 a4 quattro work in my 99 quattro tiptronic both cars are 1.8t but the 96 is not tiptronic.thanks
Old Nov 11, 2007 | 10:34 PM
oettinger1919's Avatar
SoCal Crew Member
Default RE: will it work
umm No?
Old Nov 11, 2007 | 11:55 PM
MistaGanja's Avatar
You trying to put a 5-speed tranny in ur 1.8l 99 huh? yeah it will prolly take alot of planing and work but with the tranny and pedals and stuff, and the right ECU i think it could work but not worth it in my opinion
Old Nov 11, 2007 | 11:58 PM
Bondga's Avatar
yes it will work but, you will need to make sure you get the car programed to run with a diff traynny. assuming they are both autos. do these cars have tranny computers or is it all in the ecu. if its got it's own tranny computer then you should just need to make sure you put the right tranny cfomp with the right tranny
Old Nov 12, 2007 | 12:37 AM
Trey25's Avatar
No it won't work. You're swapping auto to trans, you'll need all the accessories to make it work.
Old Nov 12, 2007 | 01:18 AM
oneg's Avatar
ORIGINAL: Trey25
so it will work? just with some effort.
yeah it will bolt up but the logistics of it isnt so simple, ecu and computers will have to be changed, may i ask why you want to? if its not a great reason it might just not be worth it.
Old Nov 12, 2007 | 11:15 AM
I'm asking this because my tranny may be going up both the trannys are auto quattro trannys just one came from a 96 which is not tiptronic but I have seen in a DIY that you can add tiptronic to a none tip tranny car.
Old Nov 12, 2007 | 02:18 PM
onepoint8tee's Avatar
Are you getting this tranny for free or something? It might work, but Id much much much much much rather get a tip tranny. There is really no other reason to downgrade if youre not getting it for free. Hit up www.shokan.com for a usedtip tranny quote.
Old Nov 13, 2007 | 08:16 PM
Lazer Viking's Avatar
so uh... where did you find a 96 1.8 ?
Old Nov 13, 2007 | 09:01 PM
I found one in a local junk yard
ORIGINAL: Lazer Viking
