WINDOW REGULATOR HELP PLEASE!
Old May 19, 2007 | 06:53 PM
littledude19's Avatar
Member
Default WINDOW REGULATOR HELP PLEASE!
Guys, My right front window will not close any more. I opened up the panel and my green plastic piece on my window regulator shattered causing my window to stay at the bottom.
1. Can I somehow prop the window to stay up manuallly without that green little lifter part?
2. Can I just purchase a new green little lifter part? Because I was told I have to get a whole new window regulator. just for that little green lifter.
Please Help Guys.
Old May 19, 2007 | 07:21 PM
auditech79's Avatar
Default RE: WINDOW REGULATOR HELP PLEASE!
The A4 window regulators have to be replaced as a whole unit, the plastic lifter isn't available seperate like it is on the A6. That goes for both the B5 and B6.
Old May 19, 2007 | 08:03 PM
Member
Dang it!
Old May 19, 2007 | 11:21 PM
acetrebo's Avatar
Junk yard. pull of the door panel, grab your little green plastic piece.
Old May 20, 2007 | 01:46 AM
veloracer's Avatar
Better yet, if you can get ahold of one of the new metal pieces, use that one. If you replace it with another plastic piece, that one will eventually break as well. VW has a 7 year "targeted warranty extension" for this very issue... the plastic pieces become brittle and shatter. This happenned twice on my old VW. Too bad no Audis are included in this extension. I've been hearing numerous people on this site having the same problem. From my understanding, all VW cars 2003 and up have the new metal clip instead of the plastic clip, and this includes Audi as well.
http://www.theautochannel.com/news/2...05/150082.html
Old May 20, 2007 | 08:33 AM
iamscottevil's Avatar
my 97 a4 , you need to remove the screw in the handle, the handle sleeve, the two screws holding the door in where the handle is, and the two on the top sides of the door, and then you disconnect all the connectors. You undo the four torx bolts (keep the spacers) and remove the whole unit from the door and loosen the clamps on the glass, remove the glass, Drill out the 8 or so rivets, re-rivet the new regulator on, reassemble and it works fine. Have had to do it to both front doors so far.
auditech79
Jan 16, 2014 11:03 AM
h4x0r
Dec 31, 2011 12:20 PM
turbo kraut
Nov 14, 2007 11:30 AM
hcho2000
Jul 21, 2007 12:23 PM
ericf52389
Oct 28, 2005 01:28 AM
