windshield washer function
Old Jun 30, 2007 | 08:51 PM
flake's Avatar
Default windshield washer function
Is there a way to use the windshield washer function without spraying the headlights all the time??
Old Jun 30, 2007 | 08:56 PM
auditech79's Avatar
Default RE: windshield washer function
Read your owner's manual. The headlight washers won't activate un-less the headlights are ON.
If they are coming onwhen the headlights are offof you got problems.
Old Jun 30, 2007 | 09:15 PM
flake's Avatar
I am in Canada and the car was originally for the U.S so now the headlights have been made to work like daytime running lights. Would this be why?
Old Jun 30, 2007 | 09:29 PM
auditech79's Avatar
I guess, if the low beams are always on, that means the headlight washer relay is activated so they would activate so yes.
Old Jun 30, 2007 | 09:44 PM
flake's Avatar
Anyway to disable the headlight washer relay. maybe pull a fuse or something. Idon't really like that feature becasue the windshield washer fluid goes all over the cars hood!
Old Jun 30, 2007 | 09:48 PM
auditech79's Avatar
You can't take out the relay because it powers other systems, but you can take out the fuse thats located on the driver's side by the cluster.
Old Jun 30, 2007 | 09:53 PM
flake's Avatar
What if I disable the daytime running lights and put the car back to US specs? btw howdo I do this? The dealer I bought the car from rigged up the lights to be always on so they can pass inspection in canada.
Old Jun 30, 2007 | 10:00 PM
auditech79's Avatar
Man i don't know, i would imagine the tech re-wired the headlight switch to ignition switch power.
I never had to do thisbut i would assume there might be a specific process in canada for this, i would ask one of them.
Old Jun 30, 2007 | 11:49 PM
flake's Avatar
I read on the quick reference guide that the daytime running lights for canadian models are only supposed to be the fog lights and the tail lights not the headlights.I wonder how i could change the wiring sothey run properly.
steve53mg
B7 Models
Jan 22, 2017 12:47 AM
mcanedo92588
Jul 1, 2013 11:27 PM
norcal89451
Feb 26, 2013 10:25 PM
sonex2000
Dec 2, 2008 05:26 PM
miabhai_freaked
Mar 2, 2006 08:57 PM
