Which wire to tap into for antenna? (aftermarket h/u)
Old Nov 20, 2007 | 05:56 PM
pyropenguin's Avatar
Default Which wire to tap into for antenna? (aftermarket h/u)
I'm finally getting around to hooking up the correct antenna adapter for my head unit, but I'm stuck. I need a 12v power supply to splice the adapter to, which wire can I tap into?
Thanks
Old Nov 20, 2007 | 08:15 PM
hollisterrobsta's Avatar
Default RE: Which wire to tap into for antenna? (aftermarket h/u)
Use the remote wire from the aftermarket H/U. I believe you need a 5v not a 12v wire, which makes the remote wire perfect. If you require 12v you could always splice into the H/U's power wire, or you could run a wire to the fuse box and attach it to something like "ACC" or a Cigerette Lighter Fuse, those will both be 12v.
skeedy
Jul 14, 2009 08:28 AM
pete7
Oct 13, 2008 03:29 PM
converted
Oct 20, 2007 04:38 AM
SnowSurfns
Jun 6, 2007 10:58 PM
kryptor
Nov 10, 2005 08:21 PM
