Wiring Diagram!
Old Dec 23, 2007 | 09:13 PM
Rhinop21's Avatar
Default Wiring Diagram!
Where can I get a wiring diagram for a 1998 A4 1.8t. Im trying to install a new head unit and im seeing so many wires from the stock one and not as many for the new one thanks.
Old Dec 23, 2007 | 09:22 PM
ImTheDevil's Avatar
Default RE: Wiring Diagram!
As long as you have the adapter harness (search "metra harness" on here), you'll be taken care of. You may have features like noise-sensitive volume control or other things like that, which will require wires, but which won't be included on your new head unit. Things like that will be eliminated with the new head unit. If you get the proper adapter harness, you'll be set, since each connector on the car's harness is unique relative to the others. This ensures that you can't accidentally plug it in wrong, and you'll have all the connections you need to hook it up properly.
Old Dec 24, 2007 | 01:11 PM
MrFlippant's Avatar
This may be helpful:
https://www.audiforums.com/m_622462/tm.htm
Good luck, have fun!
Old Dec 24, 2007 | 05:12 PM
itsbigj05's Avatar
^i know that link helped me a ton.also, if you look on the top of your stock head unit there's a sticker that shows a simplified wiring diagram.
vtraudt
Oct 10, 2013 01:33 PM
trev123
Mar 20, 2013 03:27 PM
shortie88
Oct 19, 2008 09:31 AM
ddr
Aug 19, 2008 09:14 AM
Darthgeese
Sep 8, 2007 04:41 PM
