Working under the car...
Old Nov 9, 2004 | 12:21 PM
dudley doright's Avatar
Default RE: Working under the car...
CLCONVERSION,
Can you tell us where the tech puts the lift pads?
Old Nov 9, 2004 | 12:43 PM
clconversion's Avatar
there is a little lip that hangs down behind the front wheels and right in front of the rear wheels those are the lift points for most Audi's
Old Nov 9, 2004 | 05:06 PM
You can't use those lips, it will get chewed up.
Old Nov 9, 2004 | 05:09 PM
no those are the proper lifting points I think it should even show you in your owners manual I think
Old Nov 9, 2004 | 07:15 PM
That lip was good if you use the jack supplied with the car, otherwise the jack will chew it all up.
Old Nov 9, 2004 | 07:22 PM
99a4audi's Avatar
i have a 99, and the oil plug and filter r right in front of the car very easy to get to. i jacked it up prob about 7inches and had plently of room to remove the plug and oil filter. Took 15 mintues. i dont know where the plug and oil filter is on the 2000. I just used a jack no jack stands (not that smart) but im lazy.
Old Nov 9, 2004 | 07:39 PM
brrman's Avatar
for a hydraulic jack I use the big knuckle just in past the wheel well where the lower control arm connects - you will see what I mean when you look.
Old Nov 9, 2004 | 09:58 PM
  #18
david9999's Avatar
Never get under a car supported only by a jack. Not worth the risk to save 10 dollars on the oil change.
Old Nov 9, 2004 | 10:03 PM
  #19
99a4audi's Avatar
ya not the smartest thing ive done, but i am investing in jack stands. I just didnt want ot bring my car down to jiffly lube and i didnt wanna go over the 3000 miles mark.
Old Nov 9, 2004 | 11:59 PM
  #20
Auditwins's Avatar
Lifting points found.
On the rocker panels on both sides of the car are little arrows which indicate lifting points. Just checked the owner manual and it shows lifting points for workshop hoist.
