Is it worth it to build a heat shield in between my Air intake and the main engine?
^^^ Good point fixed it for you!! lol
ORIGINAL: Beer Mod
If you had a turbo car that has a BT on the stock side mount then YES! If you have a FMIC on a k03/k04 then NO! If you have a BT and a FMIC then get water injection
ORIGINAL: Beer Mod
that is a horrible explanation that doesn't even make sense. im sorry, but it doesn't..
basically, if you have ANY engine, and ANYtype ofmods(especially a cone filter), then YES! get a heatshield. period..
ORIGINAL: onepoint8tee
Is it worth it to use a condom if I dont want to be some babies daddy?
and a turbo car or not, heat soak is a bad thing..... just engine soaking up the heat or turbo soaking it up, either way a bad thing
and i doubt there are proven hp#'s for loss, but loss is loss and with how much of a turtle our cars are, we need all we can get
ORIGINAL: sean1.8t
wow... i feel somewhat dumber for reading that..
that is a horrible explanation that doesn't even make sense. im sorry, but it doesn't..makes some sense, but poorlogic...
basically, if you have ANY engine, and ANYtype ofmods(especially a cone filter), then YES! get a heatshield. period..unless you have a true cold air intake
ORIGINAL: Beer Mod
If you had a turbo car that has a BT on the stock side mount then YES! If you have a FMIC on a k03/k04 then NO!actually you wouldstill want one, cause granted you have an fmic the heatsoak you get will make your gains unnoticable
and a heat shield for the same reason as stated above
ORIGINAL: sean1.8t
ORIGINAL: Beer Mod
All high hp turbo cars use a thing called a FMIC it takes the hot air and cooles it down before it makes it's way to the intake. If you think the hot air under the hood is bad just hhink how much hotter it is after it passes through the turbo.
Bottom line IF you have a good intercooler and or water injection you have no use for a lil heat shield period!
ORIGINAL: turbo kraut
ORIGINAL: sean1.8t
ORIGINAL: Beer Mod
The heat underthe hood is so minor when compared to the heat from the turbo that the air has to pass through before making it to the intake mani.
ORIGINAL: mschwister12
I'm leaning towards making myself a heat shield.
ORIGINAL: Beer Mod
Heatsoak is when the intercooler is overwhelmed by heat from the turbo. A good intercooler should counter this.
a good heat shield will make upm for a lower quality intercooler
