View Poll Results: A poll
Yes
66.67%
No
33.33%
Voters: 12. You may not vote on this poll
Is it worth it to build a heat shield in between my Air intake and the main engine?
Old Dec 2, 2007 | 08:48 PM
  #21
mschwister12's Avatar
Default RE: Is it worth it to build a heat shield in between my Air intake and the main engine?
I'll check the HP number before and after. I'm making it myself so I can always take it off.I'll let you know tho. I mean I don't have much HP to lose anyways haha.
Old Dec 2, 2007 | 08:54 PM
  #22
Beer Mod's Avatar
ORIGINAL: turbo kraut
ORIGINAL: Beer Mod
Heatsoak is when the intercooler is overwhelmed by heat from the turbo. A good intercooler should counter this.
The heat underthe hood is so minor when compared to the heat from the turbo that the air has to pass through before making it to the intake mani.
you are correct....... to a point,but most people run such small intercoolers, that they can't get rid of the heat...
a good heat shield will make upm for a lower quality intercooler
It won't make up for it but MAYBE help...................maybe
Old Dec 2, 2007 | 09:02 PM
  #23
chaos92287's Avatar
heatshield really wont do anything on a forced induction car since the intake air is compressed and therefore heated before it goes to the cylinders, thats why we have IC's, to cool the air back down
so getting a heatshield would mean you are spending money to cool down air only to have it get heated again.
Old Dec 2, 2007 | 09:06 PM
  #24
sean1.8t's Avatar
ORIGINAL: sean1.8t
ORIGINAL: Beer Mod
If you had a turbo car that has a BT on the stock side mount then YES! If you have a FMIC on a k03/k04 then NO!actually you wouldstill want one, cause granted you have an fmic the heatsoak you get will make your gains unnoticable
If you have a BT and a FMIC then get water injection and a heat shield for the same reason as stated above
wow... i feel somewhat dumber for reading that..
that is a horrible explanation that doesn't even make sense. im sorry, but it doesn't..makes some sense, but poorlogic...
basically, if you have ANY engine, and ANYtype ofmods(especially a cone filter), then YES! get a heatshield. period..unless you have a true cold air intake.. and what does a "ture" cold air intake come with?.... a heatshield
Old Dec 2, 2007 | 09:10 PM
  #25
Beer Mod's Avatar
ORIGINAL: chaos92287
Well at least 2 of us are on the right page!
Old Dec 2, 2007 | 09:14 PM
  #26
sean1.8t's Avatar
yes, but all forces acting together will yield a lower IAT.. the heatshield is not as important as the intercooler, or WMI (if you also have that). but of coarse it still does it's part.
and yes, the intake charge is pressurized to a certain PSI by the turbo, which is what causes the heat in the intake charge. but come on, you can not tell me that lowering the temperature air that goes into the turbo does not help. it helped on my k03 setup, and now it helps on my BT setup.. im not just going off of common sense. but real world experience here
Old Dec 2, 2007 | 09:18 PM
  #27
ImTheDevil's Avatar
Christ, here it goes again.
Old Dec 2, 2007 | 09:20 PM
  #28
sean1.8t's Avatar
ORIGINAL: Beer Mod
ORIGINAL: sean1.8t
ORIGINAL: Beer Mod
If you had a turbo car that has a BT on the stock side mount then YES! If you have a FMIC on a k03/k04 then NO! If you have a BT and a FMIC then get water injection
You sir are an idiot!
All high hp turbo cars use a thing called a FMIC it takes the hot air and cooles it down before it makes it's way to the intake. If you think the hot air under the hood is bad just hhink how much hotter it is after it passes through the turbo.
Bottom line IF you have a good intercooler and or water injection you have no use for a lil heat shield period!
oh yes, i know exactly what the FMIC does on my car. you don't have to worry about that.. but as i said, all links in the system does their part. the heatshield is not as important as the intercooler, DUH! but it plays a still, important part..
Old Dec 2, 2007 | 09:22 PM
  #29
Beer Mod's Avatar
Do you have any proof that it "helps" ie dyno runs, track times, 1/4 mile times...............
Old Dec 2, 2007 | 09:26 PM
  #30
chaos92287's Avatar
ORIGINAL: sean1.8t
thats what i thought but common sense just seems to dictate that it really isn't doing anything. and wouldn't putting a heatshield like the one from AZ make your engine run hotter? its keeping all that heat in a smaller area now that you've sealed it off from the intake...just some thoughts i was having...
