WTF!!!!!
Old Apr 3, 2007 | 10:20 PM
scotts custom's Avatar
Default WTF!!!!!
ok, i have had my n75h for about an hour now and i still can not find a way to get off the oem clamps on the old n75. i have tried a screwdriver, prying it off and everything else. the space is so cramped and the clamps are backwards so i can not get them off.
Please help!!!
[IMG]local://upfiles/24830/39CD6BA0990040CDAB7BAFE6412E867F.jpg[/IMG]
Old Apr 3, 2007 | 10:24 PM
Audi_Skydiver's Avatar
Default RE: WTF!!!!!
Try a pair of wire snippers or something like that to just cut them off.
Josh
Old Apr 3, 2007 | 10:25 PM
BaconBait's Avatar
Something like the pic below. But the tab theat's bent is sideways instead. Once you straighten it a bit, use a pair of pliers to twist and yank the F'er off.
i have but the cutters are either too big or the clamp is faceing the otherway
Old Apr 3, 2007 | 10:29 PM
cincyTT's Avatar
I'm make believe
you need the tiny flathead screwdriver. the ones that people would use on eyeglasses and stereo equipment. You pry the tip up and then use a regular flathead and pry it up the rest of the way.
Old Apr 3, 2007 | 10:30 PM
Just try using your teeth!
Just kidding... Um what about a... crap just forgot what I was going to say...
I will remember...
Umm....
I will get back to you on that one.
Josh
Old Apr 3, 2007 | 10:31 PM
BaconBait's Avatar
Put one part of the pliers on the tab at point B and put the other half on the opposite edge of A. Then squeeze. Be careful to not pinch your hand if the pliers slip. Cause it sucks.
Another thing you can do is grip the pinched bulging point and pull on it intil is straightens out a bit, then pull the hose off.
Old Apr 3, 2007 | 10:38 PM
onepoint8tee's Avatar
Tin snips, and lube up the hoses so it may be possible to twist the clamps around to get at a good angle.
Old Apr 3, 2007 | 10:41 PM
ORIGINAL: onepoint8tee
Thats what I was trying to say! LOL
josh
Old Apr 3, 2007 | 11:14 PM
VW01AUDI00's Avatar
Try using a small flathead screwdriver than stab your self in the thumb.Than dance around saying stupid f**k*** clamps thats how I do it.
