WTF!!!!!!!!!!
Old Sep 26, 2007 | 12:56 AM
NuYorka103185's Avatar
Default WTF!!!!!!!!!!
So I get my short block I bought shipped to the shop and get my car towed up there. Then they tell me they can't do it because the water pump is in a different spot. Everything else is perfect. WHAT THE HELL IS THIS!!!!!! So according to them the motor I bought is useless. Does this sound strange to anyone else?
Old Sep 26, 2007 | 12:57 AM
AA4Tristan123's Avatar
Default RE: WTF!!!!!!!!!!
sorry to hear that man
Matt
Old Sep 26, 2007 | 12:19 PM
wood_e's Avatar
Sounds like BS to me. Who cares if the WP is in a different spot so long as it's turning via the belt? I'd get that to another shop ASAP...
Old Sep 26, 2007 | 12:23 PM
The Bishop's Avatar
Just go to summitracing or jegs, and get an electric water pump. then you can put it where ever you want.
Old Sep 26, 2007 | 02:26 PM
acetrebo's Avatar
Same engine code and all? Its engraved on the block, you'd think the same engine codes would be the same.
Old Sep 26, 2007 | 02:36 PM
cincyTT's Avatar
I'm make believe
Im guessing you bought an internal waterpump and your car is an external or vise versa
> 2000 external
< 2000 internal
You can make it work, but your going to have to do more work
VW/Audi Engine Info
-058 Block: external water pump
-06A Block: internal water pump
-Displacement: 1.8L (1781cc)
-Firing Order: 1-3-4-2
-Cylinder #1 is next to the timing belt
-All catbacks are 2.17"
-Oil Capacity: 4.6qt (4.35L)
-Head bolt size: 11mm AEB, 10mm all others
-Engine Mount Assembly/Mounting Info
Old Sep 27, 2007 | 12:10 AM
so it is possible. Damn my 2000 haha no K04 file for 2000 auto/tip ONLY 2000 and now this my borderline year car haha. Okay what info should I know cuz I'm gonna have them do it anyway I can't afford to be out of a car for any longer its been a month already
Old Sep 27, 2007 | 08:38 AM
david9999's Avatar
Call GIAC directly. They said they do in fact have a K04 file for the 2000 tiptronic.
Old Sep 27, 2007 | 01:02 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: NuYorka103185
Im just read up and you have a ATW engine code that still uses a 058 block (the only other is the AEB) with an external waterpump and im guessing you got a internal waterpump engine (06A block). You should do a search on vortex in the 1.8t section. You can install it, just need to take care of a few differences (waterpump, crank pulley setup, sai and valve cover breather)
Old Sep 27, 2007 | 02:13 PM
would the differences be a pain in the a$$? The shop said they could do but not sure if they want to : / So when you say search the vortex 1.8t section what should I serch for (remember I'm not mechanically savvy)
