xenon problems
I would like to know how I solved the problem of xenon in my car because when I ignite the xenon system the car to me it gives an error me of the brakes and single it happens to me when I ignite xenon. i want to know if a cant put xenon in my audi a4. i want to know what kind of xenon I can installed
I need help with that thanks a lot.
yes u can use xenon on A4's.When u open the lights,u will get an error light for a while than it will disappear.The reason that the ECU dedects low voltage from the lights and it gives er.code than it thinks that the light is working and close the eror light back.But this will not couse a problem for your car except stupid lights.
I guess what prodrive said about the error light is correct but as for a sightHID's You do know that the 3800K to about 6000K are the best for actual visual light out put. but I guess if you live where thats not really an issue any you are looking for the astetics you can go with the higher kelvin numbers. good luck and welcome to the forums.
AudiOso
Dec 16, 2008 12:35 PM
PartsPro0101
Jul 30, 2008 08:22 PM
