Audi A5 This sleek mid-sized A5 coupe offers performance with a roomy interior.
2001 A4 B5 AWM Rough Idle P0300 P0303 P0304 P0441 Need catch can?
Old Dec 26, 2012 | 12:07 AM
Giga's Avatar
Default 2001 A4 B5 AWM Rough Idle P0300 P0303 P0304 P0441 Need catch can?
Car has new heated O2 sensor, new air filter, cleaned MAF sensor and Berdohl Protex Fuel System cleaner done purchased from Audi store. Car runs fine until I give it a good rev. Thinking I might need a catch can to replace the PCV system. Checked the spark plugs and Ignition coils, spark plugs were Aitolite double platinum and gapped around .40 give or take which I thought was a little excessive. My coils are scheduled to be replaced by Audi on Saturday since they were recalled. Really hoping to get to the bottom of this loss of power, rough idling and engine misfiring. Any advice would be much appreciated. Thanks in advance and Merry Christmas!
Old Jan 5, 2013 | 07:50 PM
Res72's Avatar
Did you ever find your fix? I'm having similar issue on my 97 a4 2.8q throwing p0304 with only symptom being shudder during accel.
Old Jan 6, 2013 | 09:25 PM
Giga's Avatar
I've done some research and got it down to a couple of issues. 1) Replacing the MAF sensor, tomorrow 2) Replacing the fuel filter, just because I'm sure it needs to be replaced and 3) Possibly installing a catch can on the PCV system. Mann fuel filter will be here Tuesday. Will update as I go
Old Jan 6, 2013 | 09:44 PM
Giga's Avatar
Old Jan 27, 2013 | 01:38 AM
Giga's Avatar
Replaced my fuel filter MANN and MAF sensor BOSCH. Started the car and problem was still there except now its only was only misfiring on cylinder two P0302 P0300 AND P0171. Thinking it may be a vacuum line since the engine, I believe, was swapped.
Old Jan 28, 2013 | 08:50 PM
ImTheDevil's Avatar
Likely a spark plug that's crapped up or loose. Change them - they're cheap for a 2.8. Get all new ones, gap them at .040" I believe for the 12v engine, and see if it goes away. I had the same issue on my 30v.
To the OP, your plug gaps are too wide - whether it's a 30v V6 or a 1.8T, you need a .032" gap for a stock engine, and .028" if you're chipped.
Old Jan 29, 2013 | 09:45 AM
Res72's Avatar
I did change plugs , with oe ngk's . Did not take care of problem. Although, did see a marked increase in power. Ran 1.5 cans of seafoam through fuel and shudder disappeared , for now , still throwing p0304 though... looked into replacing ignition power output stage module but 250$$ is a bit much for a maybe .. anyone in Rockwall Tx area have vag comm?
wenglish
Mar 31, 2012 09:44 AM
chongboi
Apr 26, 2010 07:09 PM
CALI KID
Sep 23, 2008 03:20 PM
traian2003
Mar 30, 2007 09:05 PM
