Just finished replacing the turbo (for the second time)
Started the car up to heat it up to change the oil - did fine
Changed the oil - now no crank no start
I get all the dash lights and the MMI comes on - had the battery tested - good
checked the fuel pump fuse (25A) - we are good there
checked fuel pump relay - good - checked starter relay - good
wife tried to start when I was listening under the back seat - no sound - is there an easy fuel pump test?
Do the Computer hold the crank out if there is no fuel pressure?
Or could it be the Starter? - whats an easy way to test?
Any suggestions on where to go next?
JPJM
JPJM
