Audi A5 This sleek mid-sized A5 coupe offers performance with a roomy interior.
A5 S-line 3.2L ENGINE LIGHT
Old Jan 13, 2019 | 12:38 AM
amirmehrabi's Avatar
Default A5 S-line 3.2L ENGINE LIGHT
I have recently purchased my 2009 A5 S-line. The engine light just came on, however the car seems to be running perfectly without any seeming issues.
edit*
hooked it up to the diagnostic, shows a throttle error. P0068. manifold absolute pressure sensor(MAP)/mass airflow sensor(MAF)/throttle position correlation.
probably the sensor needs changing but who knows. might have to take it to the mechanic.
Does anyone know a website you would use to get part numbers for audis? e.g. for bmw you would go to realoem.com
Old Jan 15, 2019 | 11:16 PM
Default edit
Took the car to mechanic who connected it to the diagnostics and the following codes came up.
P2070 Intake manifold tuning valve bank 1 stuck open
P307A Intake system airflow too low
P0068 Map/Maf throttle position correlation
I did a bit of research and it appears it might be caused due to carbon build up in the hose connected to the air filter or else leaks.
No one seems to comment, anyone have any ideas?
Old Oct 8, 2019 | 11:32 PM
Coby Henry's Avatar
Default Oh boy!
This could be a tough gremlin to diagnose.DO a pressure test on your cylinders. I was having the same issues. I replaced all of the upper gaskets and seals, the ignition coils, plugs, rear engine seals and map sensors. It went away eventually, but I was down 4k in repairs.
Mikey330
Nov 29, 2022 04:53 AM
Demzaduia5
Apr 15, 2015 08:22 AM
virtuala5
Sep 3, 2011 10:08 AM
atomic619jd
Sep 30, 2010 03:00 PM
andyblue252525
Apr 20, 2008 06:55 PM
