'01 A6 2.7t - limp mode/loss of power troubles
Old Dec 9, 2013 | 06:59 PM
mwaudi01's Avatar
Default '01 A6 2.7t - limp mode/loss of power troubles
I am looking at a 2001 A6 2.7t quattro, automatic transmission. 17x,xxx miles. From the information I can get from the seller it was modded by a previous owner (has "pipes", the throttle body Y boot looks like it may be aftermarket, and aftermarket turbos). Seller says a few weeks back they started having problems with it going into and out of limp mode after driving between 1-3 miles. Its been sitting at least two weeks so the car won't start but it will crank (probably just a dead battery seeing as it was close to 0 degrees f when I tried).
After reading the codes with a generic obdII scanner (not VAG-COM) I get code P1367. The EPC light is on, the check engine light is on, the traction light is on (triangle), the ABS light is on, the battery indicator is on. The center display's pixels next to the speedometer are scrambled to the point you can't tell what is going on.
Is a P1367 enough to make it go into limp mode or is there a larger problem that should be looked at?
Any advice would be greatly appreciated. I apologize if I am asking stupid questions or making stupid statements but I'm new to repairing cars. Trying to learn as I go along.
Old Dec 10, 2013 | 03:27 AM
Nebuchadnezzar's Avatar
I quick looked up P1367 and it seems like it's to do with a wiring fault to one of the coils. A misfire would certainly reduce performance.
I would first start by getting that battery checked for its current CCA capacity. I know electrical faults can cause all kinds of weird things to happen, such as almost every warning light to go on like you're describing. Assuming the engine is running, that is. I think in the accessory position most lights will be lit. Either way, I would still get that battery checked as it could easily knock 100+ off of the asking price without the owner being able to argue about it.
Old Dec 10, 2013 | 09:42 AM
mwaudi01's Avatar
The battery will be the first thing checked when it warms up outside or garage space can be found. Before I think about purchasing the car I want to see it run even if its not at peak performance. Also I want to see if it shifts smoothly (from the little research I've done it seems that transmission repairs can be rather expensive.)
As far as the P1367 is concerned do I replace the coil pack or wiring somewhere?
Thanks
Old Jun 19, 2014 | 01:04 AM
User2001's Avatar
HI ,
Where you able to find the problem? It seems my car decided to go limp after ext lights came on.
Thanks
hjheap1
May 8, 2011 03:26 PM
Diefen
Feb 26, 2010 07:56 PM
Danik
Jul 1, 2008 03:20 PM
nemohm
Apr 23, 2008 01:38 PM
Indiepunk
Jun 22, 2007 08:42 PM
