02 2.7t - smoke on startup
I just noticed smokewhen starting from cold - I realize this is a problem
but dont know what the most probable causecould be - and dont really want to go to the local Audi dealer with it until I understand it better...
any advice?
but dont know what the most probable causecould be - and dont really want to go to the local Audi dealer with it until I understand it better...any advice?
any new updates on this, i know its an old thread but I am having the same issue with my 2.7t. It appears it has just started to do it, but it has a rather large cloud of smoke!
In my previous cars i have had a similar problem, and it was caused by valve guide seals wearing out. My car doesnt splutter or miss. no oil in water or vice versa, and seems to have full power all of the time.
Valve guide smoke is usually blue (oil) not white.. White smoke is caused by a rich mixture. In cold weather it can be due to the vehicle running rich while warming up or condensation being blown out of the mufler.
It could mean your turbos are gone- the coolant gets into the exhaust gas.
Do you have smoke in both exhaust pipes?
What is the mileage?
Monitor the coolant level, I'd suggest.
Do search on the forum - there is a lot of info here.
its blue smoke - it only does it when i start it up in the mornings, so after its been sitting for a while...12 hours or so.
Doesn't do it any other time that i can tell.
It doesnt smoke at all either from what i can see, and I cant tell which pipe its coming out of either
sorry, not much help really!
next time i start it in the morning, i will get a friend to stand behind and check if its coming out both pipes..
sorry, not much help really!next time i start it in the morning, i will get a friend to stand behind and check if its coming out both pipes..
