02 a6 2.7 code 17887
Old Sep 18, 2009 | 05:56 PM
germansport's Avatar
Default 02 a6 2.7 code 17887
working on this code 17887 brake boost vacuum system. mechanical failure. check vacuum pump and hoses [ok] any ideas ?
thanks
Old Sep 18, 2009 | 07:37 PM
m000035's Avatar
Do the brakes work ok? (Maybe a sensor issue.)
Is it building and maintaining a vacuum?
Rough check for building and holding vacuum:
After the engine has been running and without touching the brakes, slightly crack open the vacuum line to the booster and listen for a sucking sound. If it has a vacuum, Run the car, turn it off and let it sit over night or so. Check vacuum again.
audibuyer
Oct 9, 2010 12:13 PM
CRAZYHAWK
Nov 27, 2008 08:42 PM
pathak76
Dec 12, 2007 03:35 PM
teecee
Jun 28, 2007 08:31 AM
Diavan
Jan 23, 2006 02:21 AM
