02 A6 oil pressure issue
Old Dec 12, 2010 | 02:33 AM
little_town_audi_owner's Avatar
Exclamation 02 A6 oil pressure issue
Hello
- 02 audi a6 3.0 w/ 105k
-starting tonight during a little fun in the snow my check oil pressure light came on - pulled over checked oil, couldn't see if it was low at all but it was in a blizzard so i grabbed my quart out of the bag in my trunk and put 1/2 a quart in just to top it of until i get home - arrive home, oil isnt low and nothing leaking from what i can see or smell but my check oil pressure light is still blowing up at me
- any ideas? pump? ... i would like to be back in the snow asap
-cheers, kyle
Old Dec 12, 2010 | 02:36 AM
and oil temp has been fine
Old Dec 12, 2010 | 08:25 AM
bob martin's Avatar
Could be a bad pressure sending unit. That should be what you check first. Don't you love how things like this always wait until the snow falls to happen?
Old Dec 13, 2010 | 01:22 PM
oh how that is true - this will be the third winter i own my audi and each winter something has broke within the first couple good snows and then a spend a couple of weeks taking care of the issue - each winter something went out - and my back up car is an 99 alero and its not like i can take the bike out for a spin - ugh oh audi
if anyone else has a thought please shoot it this way
thanks
Old Dec 16, 2010 | 04:10 PM
Thumbs down oil pressure sending unit problem?
After changing the oil n filter i went a day without seeing the warning to check my oil pressure - it wasnt the low oil pressure but just the check - then the 2nd day it went off for the drive home from work and the next drive that night then nothing for 2 days then it comes on again (last night) whereas all day today has been fine and ive driven it for over an hour in transit and i also have checked the oil level consistently (which it is fine) and no leaks - oil temp is fine
has anyone ever had this intermittent warning light problem or anything like it
thanks
Old Dec 16, 2010 | 05:40 PM
02A6Beau's Avatar
I agree with Bob, bad sending unit.
Old Dec 16, 2010 | 06:07 PM
hxgaser's Avatar
Could it be that you have sludge? Are you running dino or synthetic? anyways, try seafoam.
Old Dec 17, 2010 | 03:28 AM
Thanks, I'll def look at the sending unit and i just had a buddy that used seafoam and wow does that make a white cloud that covers the town and i use synthetic
Old Dec 17, 2010 | 06:49 PM
hxgaser's Avatar
Seafoam on intake will make white smoke. In your case, it is in the crank case.
Old Dec 21, 2010 | 10:17 AM
Howdy - so my next step is changing out my oil sending unit - can someone give me a brief on the operations of this - location, etc..... 02 a6 3.0 - anything special i should know or change coinciding with this
Thanks!
