02 A6 problem
I have no low beams on an 02 a6 quattro. The low beam fuses in the side of the dash are fine. High beams work fine. Assume it is a relay but can't find it.
Passenger side window is not rolling up straight. Pulled the panel and nothing is broken but has some play on the door opening side. How do I adjust the play out?
You've got to give us more info on headlights. Did they work before? What have you looked at? All relays pertaining to headlights are under driverside dash. Search headlights in forum search, there are tons of write ups on how to test relays. Does your horn work? The reason I ask is when my ignition switch went the car would start but had no headlights or horn. It weird I know but these cars are wired in strange ways. So when you just say my lowbeams don't work no-one is going to answer because they don't want to trade 10 messages for info. you failed to provide.
All I know is the low beams do not work. Don't know when they stopped or how long ago they did work. Horn works fine, high beams work fine, blinkers work fine, ect. Without a wiring diagram it is hard to figure out what is going on. I found a fuse box on the side of the dash. Checked the fuses using the chart inside. The left and right low beam are getting power on that side of the circuit.
Anybody have a wiring diagram?
As I stated before, click the forum search box and search headlights and related key words. There are wiring diagrams and relay tests you can do. The headlight relays are under drivers dash, you're going to have to remove that cover under there. As I think and write I was looking for independant foglight mod. When I seen those write ups, so type in foglight mod.f they don't show on this forum try(audizine forum, audiworld forum) I've seen what you need just can't remember which forum. Or type independant foglight mod in google, it'll pull the forum and thread for you.
