07 A6 4.2 with P0016
Old Jan 14, 2016 | 03:04 PM
alm70's Avatar
Default 07 A6 4.2 with P0016
My 07 A6 currently has a P0016 code Bank 1: Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incorrect Correlation. I know there are many posts on this, but is it fair to say the solution seems to be all over the map? Most of them being cam shaft sensor. I read of one that it was the Intake Valve Solenoid.
The car is at the shop now and below are the codes. I'm trying not to panic. Although a timing issue, I'm assuming it isn't a guide or tensioner because I haven't been hearing any rattling or odd noises at start up.
With the rough idle there are misfires on 1, 5 , 4. Are the locations of these misfires important to my code? These are actually the first 3 cylinders in order that the car fires the engine. Does this mean anything? Does it mean anything the cylinders are on opposite sides?
Here are the codes.
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 001 - Incorrect Correlation - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:50:39
Freeze Frame:
RPM: 721 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 13.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000769 - Cylinder 1
P0301 - 008 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000773 - Cylinder 5
P0305 - 008 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 167076 km
Time Indication: 0
Date: 2016.01.08
Time: 08:51:46
Freeze Frame:
RPM: 736 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 33.0°C
Temperature: 14.0°C
Voltage: 13.716 V
tscottk
B8 Models
Jun 3, 2015 01:18 PM
JasonPetralia
B8 Models
May 18, 2013 02:34 PM
