18" wheels with spacers? HELP!
Old Dec 9, 2005 | 12:44 PM
horizontal8's Avatar
Default 18" wheels with spacers? HELP!
Hi everyone.
I'm looking at getting a set of 18" wheels for my 2001 A6 2.7t and it looks like i'll need 20mm spacers to clear the brakes. Are these spacers safe or should i avoid putting them on the car. Any info or recommendations are appreciated. also, how much would these spacers cost me? Thanks.
Old Dec 9, 2005 | 07:59 PM
slee22's Avatar
Default RE: 18" wheels with spacers? HELP!
I think there are quite a few Audi owners that run spacers, but it would depend on how thick they are to say if they are unsafe. What size are they?
Old Dec 16, 2005 | 02:31 AM
cedric's Avatar
Hey Man, I have a 2000 A6 2.7T. I bought some universial spacers from ebay and was told that I could use stock lug bolts. WRONG! Front wheel came off and messed up my fender and alignment. I found a spacer made by EIBACH thats custom fitted for the A6 and comes with extra long lug bolts. They come in sizes from 5mm up to the 20 and 30 mm size you need. I got them for about $72 a set. You can go to the EIBACH website and find out where to order them. The universal spacers don't stay put. If all the bolts aren't equally tight at the same depth, the wheel will work itself lose and come off. Stay away from those universial spacers.
Old Dec 16, 2005 | 02:46 AM
Kievskiy's Avatar
20mm -> ALOT!!! Exit ramp and your out...my friend had 18mm spacers on a4 and that was bad choice.....i'm running spacers too but its only like 7-10mm on longer aftermarket bolts, get them made at some mashine shop exact for your set up.good luck.
Old Dec 26, 2005 | 02:23 PM
i have no idea where to buy sumer wheels for my car (2001 A6 2.7T) everywhere i look people say the rim wont clear the HP2 brakes. I dont want to get factory wheels. Can someone reccomend a place where i can get a decent set of OEM 17's or 18's? Thanks everyone.
Old Dec 30, 2005 | 03:50 AM
Kievskiy's Avatar
Well, check any wheel shop, all you need is 35mm offset on the rims, Just tell them that, try to do it locally so you wont have problems with fitment.
Lcbusa1300
Aug 30, 2013 07:12 PM
Reapsy
Aug 14, 2011 06:07 AM
pullacowonaski
Oct 15, 2009 02:15 PM
jr vq 30 de
Aug 19, 2009 02:28 PM
formula
Mar 2, 2008 09:39 PM
