18" wheels, what size tires?
RE: 18" wheels, what size tires?
Don't forget that the answer to this question depends on two bits of info the original poster did NOT provide: body style (4.2 wide body or narrow body) and wheel offset. With the right offset, you can go as high as 255 on the 4.2. 235 is the max on the narrow bodies.
the offset is 35inch on the 18's. 2001 a6 4.2. Was not aware that they had a wide body and narrow body. When they do the math at Les Schwab they say that 245/40/18 works out to be the same as the 255/40/17's that are currently on there. So that's why I figured I could go with the 245's. I would love to go with 255/40/18's so that they fill out the well a bit more.
