1995 A6 Quattro Lost Ignition
Old Jun 12, 2006 | 08:26 PM
Jaimestoy's Avatar
Default 1995 A6 Quattro Lost Ignition
Dear Fellow Audi A6 Guys
Wifes wagon started pressurizing the cooling system, so dismantled, Did Not Disconnect the Battery, ??? Maybe new culprit ???? Proceded and found beginning of head gasket lead, some bolts not up to origional torque, planed the heads .004 all cool , back together, all hooked up , Cranked and have fuel but no Ignition, Has automatic so in R/H foot well is trans and engine computer, no power at 3 pins of power output stage, ( ignition unit on R/H firewall ), I have Mitchell CD and not a Bently manual and am challenged, Says look for Fuse 32 if no power to coils.... only 21 on L/H side of Dash???
Any specialists out there with A6 experience
the Mechanical is fine, normally something simple but has me by the butt, Any inputs appreciated
Pete and the Peek family
Old Jun 17, 2006 | 11:56 AM
dankhound's Avatar
Default RE: 1995 A6 Quattro Lost Ignition
Condsidering everything was ok before the head gasket, its probably something you did durning the change that is causing the problem. Check to make sure you have everything pluged in and that no wires are pinched or damaged.
yasser22
Jul 21, 2014 05:05 PM
keith2580
Nov 16, 2012 05:52 PM
djunified
Jun 5, 2012 11:13 PM
Wac786
Aug 3, 2011 12:47 AM
JDA1
Feb 23, 2004 07:54 PM
