1996 a6 2.8 quattro engine temp guage
Old Nov 25, 2006 | 12:37 PM
bloodshot's Avatar
Default 1996 a6 2.8 quattro engine temp guage
I have a 1996 a6 2.8 Quattro.
My engine temp gauage reads slightly over the middle area.
THat doesn't seem right to me. I believe the gauage is working properly.
What are the things I should look into? Is head gasket be one of the possibilities?
Old Nov 25, 2006 | 12:40 PM
techbod's Avatar
Default RE: 1996 a6 2.8 quattro engine temp guage
it could be ok are the cooling fans working? is there heat in the cabin? check for oil in the water and water in the oil? lose of coolant that sort of thing
Old Nov 25, 2006 | 06:45 PM
bloodshot's Avatar
no oil in water and vice versa. I just had the coolant changed. I only had one bottle of g12, so I had to use cooldex? it's SHELL brand, I forgot the name. DEX COOL?
anyways.. the needle is on the same spot, just slighly past the middle thick line. NO heat in the cabin. THe fans are working. BUt it seems like it's always working loudly.. is that normal?
dodo23
Mar 28, 2013 11:07 PM
zer0vette
Jul 21, 2010 10:30 PM
MartinCieslak1
Nov 20, 2009 01:05 PM
kbrookst
Oct 24, 2009 06:37 PM
j1234
Apr 24, 2008 05:48 PM
