Ok.. I give up and need a little help here
My drivers door handle wont open the door from the inside anymore (just felt it ' let go'). No biggie, right? Only I can't get the friggin door panel off.. I have removed the upper two screws, the ones in the handle, and found where the one behind the latch handle is suppose to be. However, the panel wont budge. After pulling various places, I feel that there is another one behind the rear wood trim, but cant seem to figure how to get that off either without breaking it...
Any help here? It's friggin COLD outside
OK.. so a crowbar and hot knife it is!
Thanks!
Thanks!
OK.. so hard was it to actually 'pull' the panel up? I found all the screws (and the one behind the latch handle, which was missing).
as far as I remember that was the "hardest" part as it was snapped in place pretty tight.
Actually I had a little more trouble when I mounted the panel back, because of the locking safety "pin" or "****". It took me a while to figure out how to keep it in place while sliding the panel's hole over it (it kept popping out from its position)
Thanks, man. Will give it another try tomorrow. I pulled, pushed, hammered, swore and cursed, etc.. couldnt get the damn thing to budge at all. Maybe the 20F temps had something to do with it, dunno
BTW, dont you sleep?
Actually I was on my way to bed when decided to check the forum one more time
It used to be diff when young, as the New Year night is a party night back in ole Europe, bigger than the Christmas...
Anyway, if all the "stops" are out of the way, you should be able to push up the panel from the bottom, as it doesn't rest against a frame groove or metal tabs (as you know already and can see). I was a bit tentative when I got the panel off, just like you (actually NH made fun of how long it took me to replace the regulator :-) ), but I'm pretty sure you'll have an "ahaa" moment.
It used to be diff when young, as the New Year night is a party night back in ole Europe, bigger than the Christmas...Anyway, if all the "stops" are out of the way, you should be able to push up the panel from the bottom, as it doesn't rest against a frame groove or metal tabs (as you know already and can see). I was a bit tentative when I got the panel off, just like you (actually NH made fun of how long it took me to replace the regulator :-) ), but I'm pretty sure you'll have an "ahaa" moment.
I haven't messed with the C4 chassis too much, but on the C5 you only have to remove the two philips screws at the top of the panel then pull it stright upwards then out. Pulling out towards you won't do you any good. You don't have to remove any door handle hardware or anything like that from what i remember. The A6 is the easiest of all the audis to remove the panels.
I always have fun - especially with people in the Midwest LOL -- When you put it back together make sure you seal the plastic sheet or you'll end up with a wet carpet when it rains.. PS It takes little fingers to work on the stuff in the door... and keep the bandaids close at hand.Originally Posted by chefro
