1996 A6 Quattro air conditionong problem
Old May 15, 2006 | 03:41 PM
sailfast's Avatar
Default 1996 A6 Quattro air conditionong problem
I need some help. A few days ago on my way home from work (Phoenix 100+ deg) my air was working fine about 20-25 minutes then started to blow warm air. I took it to our local fix it shop for our company trucks. They checked the refrigerant, to much they said, they charged it to the proper pressure and said it was working great. I said how long has it been running--long story short they test drove it - same problem 20-25 minutes, searched for a short from the compressor but couldn't find one. any one able to help???
Thanks,
sailfast
Old May 20, 2006 | 01:49 PM
dankhound's Avatar
Default RE: 1996 A6 Quattro air conditionong problem
Have them check the pressures when the system isnt working. I suspect you have a moisture problem causing a blockage in an ac line once the system gets cold.
Old May 26, 2006 | 04:35 PM
audiSean's Avatar
You know, you do have climate control diagnostics on that car.
Follow the instructions on this link to access the diagnostics:
http://www.audiworld.com/tech/int5.shtml
JohnNMeLy
Feb 9, 2010 09:34 PM
soretristan
Oct 5, 2008 12:28 AM
bren
Oct 23, 2007 04:52 PM
numidian
Oct 3, 2007 06:29 PM
gerrym
Apr 16, 2006 12:51 PM
