1997 2.8L A6 Overheating??
Old May 26, 2005 | 06:13 PM
roesroes's Avatar
Default 1997 2.8L A6 Overheating??
I have a 97' A6 2.8L 12v that after about 20 minutes of driving, the AC shuts down, the coolant temp will spike when I idle or slow down. At fist fan point on the guage the coolant warning light comes on and stays on even when guage goes back to normal range. I can tun on the heat and get it to shut off and keep the temp guage from spiking but need to fix ASAP. Car has 110k on it and I replaced the thermostat, water pump, and heater core at 48k (idot I bought car from ran standard anti-freeze) Could this be that the radiator is clogging or should I go Thermostat, Waterpump, radiotor suggestions welcome.
Old Nov 30, 2007 | 05:26 PM
chancey's Avatar
Default RE: 1997 2.8L A6 Overheating??
same here
did you happen to find a solution
Old Nov 30, 2007 | 09:36 PM
NH_USA's Avatar
Is the electric fan running when it gets hot?
Old Dec 1, 2007 | 03:52 AM
FALCOR's Avatar
MINE DID THAT ONCE IN TRAFFIC WHEN IT WAS ABOUT 38 DEGREES C, IT WENT TILL UNDER 3 QUATER ,HAD TO PUT OFF THE AC TO HELP IT COOL. ???
ruthiek
Jul 9, 2013 11:39 AM
tadeo47
Sep 5, 2010 12:27 PM
No1londonboy
Mar 16, 2008 03:01 PM
No1londonboy
Mar 8, 2008 02:05 PM
tarioa4
Feb 14, 2006 07:02 PM
