1998 audi a6
Old Jul 13, 2007 | 04:32 PM
thunderCat's Avatar
Default 1998 audi a6
Hello all i have audi a6 1998 and in my dash clock i got waring lights "low oil level and abs'" but car runs just fine i have just get back from germany to england and no problems
some times all of this warings will clear and then go back again but most of the time they stay on please help me please !!!!!!!!!!!!!!!!!!!
i have try to reconnect my dash board clock and i have replace oil sensor noting have change
mabye i must replace oil level sensor ? who knows ????
Old Jul 13, 2007 | 05:28 PM
thunderCat's Avatar
Default RE: 1998 audi a6
Please help me plese !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 15, 2007 | 05:37 PM
thunderCat's Avatar
Help !!!!!!!!!!!! need some help please !!!!!!!!!!!!!!
Old Jul 15, 2007 | 07:21 PM
teranenrique's Avatar
Is the oil level low? if its not then the next part would be the sensor, just replace it. As for the ABS i have no clue, sorry thats all i could do for you.
Old Jul 19, 2007 | 05:15 AM
thunderCat's Avatar
oil level is okey !!! oil sensor has been replece it !!!!!!!! i just don know what to do next
please i need some help
Old Jul 19, 2007 | 06:07 AM
techbod's Avatar
Default RE: 1998 Audi a6
ABS needs to be checked with a diagnostic tool like VAG, oil light could be oil pressure and the oil pumps do tend to have a problem on Audi the pickup pipe gets blocked and it should be a recall although it isn't at the moment ( but it should be )
Old Jul 24, 2007 | 06:12 AM
thunderCat's Avatar
This what i have found :
Expert: Greg
Date: 4/27/2007
Subject: Audi A-6 Electrical Problem?
Question
I have a 1998 Audi A-6. Frequently the tachometer will stop functioning and, at the same time, the oil can, the ABS, and the brake lights will come on. When the tachometer resumes functioning the other lights go off. We have had the car checked and there does not seem to be any physical reason for the warning lights. It seems likely that this is a short of some kind.Taking this vehicle to my local Audi dealer is not an option, they could not diaginose a problem if it stood up and waved at them. Any ideas on where my problem may be, and how to repair it?
if(zs>0){w('+x2+'#b">Get the answer below
');zSB(1,3);w('
Answer
hello
sorry it took so long, I was asking around and nobody get this yet.I will make sure connectors are not loose at the cluster. I have seen some problems with clusters (lights on with no reason)but who knows. Make sure there is no faults in cluster, but for this you will need some scanner. If you get any faults let me know this will help a lot. OR
If you know somebody with same car 98-00 swap the clusters .
good luck pltech
Follow-Ups to Answer from Expert Greg
[hr]
A6 Avant MT writes on 2007-05-03 18:16:04
Hi, I had the same problem with my A6 2,4 Multitronic Avant some year ago. What I had to do was changing the instrument panel (Tacho and speed). I had a guarantee, luckily. The cause whas that the broker had connected both handsfree and radio att the wires for the computer system. This connectons pulls to much amps from the system causing the computer to fail. Remember that the theft protection will engage if the computer fails. (While blinking and making noise) so dont stop the car. I suggest you check your connections if you have a bad one or something connected wrong. I think you have a older bus system than me but maybe it is the same fault.
[hr]
Don Daleiden writes on 2007-07-17 16:36:41
Our Audi 2002A6 was giving similar fits on the diagnostics, found a firewall bolt piercing the wiring harness behind the left cyl.bank, several wire splices later and $750 for O2sensors we are back to proper ops. Don
Please read it and tell me what do you thing
Old Jul 24, 2007 | 05:36 PM
thunderCat's Avatar
Help somone help me pleae !!!!!!!
blacksheep
Dec 13, 2010 09:10 PM
Lebe Frei
Dec 16, 2009 12:04 AM
roofboy2
Apr 23, 2008 04:19 AM
roofboy2
Apr 20, 2008 05:07 AM
mgoblue24
Jan 5, 2007 02:26 AM
