1998 audi a6 front grille replacement
Old Jul 19, 2012 | 11:36 PM
ged124's Avatar
Default 1998 audi a6 front grille replacement
So i was considering buying a black badgeless grille for my 98 a6 2.8L from ecs tuning. does anyone have any experience on removing and installing on of these grilles? any input would be appreciated
Old Jul 20, 2012 | 12:09 AM
nm3210's Avatar
It's a little tricky to pop out, you have to find all the tabs around the inside and slowly work your way around to each one and then with a good yank it comes out. Definitely doable using only your hands and I recommend doing so as to not scratch up the paint and what not. You just pound it back in place basically.
Old Jul 20, 2012 | 01:07 AM
ged124's Avatar
ok cool thanks for the help!
Old Jul 20, 2012 | 08:16 AM
andyandjohn's Avatar
Take one corner out first then the middle and so on. When you put it back make sure the tabs (plastic) aren't bent. Use both hands, one to push the grill on the other to support the plastic mounting slot from behind. Make sure it is snug across the whole grill or it could fall out while driving.
michaiel
Jul 27, 2011 11:47 AM
rsking84
Dec 5, 2010 10:21 PM
b7lee
Nov 20, 2008 12:13 PM
sarebolia
Jul 15, 2008 11:34 AM
Audioz
Jun 21, 2007 11:30 PM
