1999 A6 2.8 rough idle? 2 other problems
Old Apr 15, 2008 | 10:18 AM
gubro30's Avatar
Default 1999 A6 2.8 rough idle? 2 other problems
Hi there!
Just bought a 1999 A6 Quattro with the 2.8, with 113,000miles on it.
The car runs perfectly, except that the idle is rough, the engine vibrates quite a lot when at stop lights, no matter if the tranny is on drive, tiptronic mode, or neutral, so we can rule out the tranny as the culprit. As soon as you give it a little throttle, the vibrations disappears.
I'm completely new to Audi/VW cars. Is this a common problem? WHere to look first?
Also, the fog lights won't turn on, and the headlight washers don't operate when I use the windshield washer with the engine running, and the headlights on, as they should.
Other question: Shall I run it on premium or regular is fine?
Thanks!!
Guillaume
Old Apr 15, 2008 | 06:51 PM
Retard Riot 686's Avatar
Default RE: 1999 A6 2.8 rough idle? 2 other problems
Welcome to the Audi side of life (the best there is). 89 octane is the lowest grade fuel recommended for Audi's i have the same car I only run premium in it though. And your positive your turning on the fog lights? You gotta pull the dial out
Old Apr 15, 2008 | 10:49 PM
madridlover's Avatar
Have the spark plugs been changed recently? What about the oxygen sensors?
Old Apr 16, 2008 | 07:20 AM
gubro30's Avatar
hi!
I will change the sparks plugs and I'll have the ICV cleaned. As for the fog lights, I'm positive I'm doing it alright, I'm pulling the dial out with the headlights on. The headlights washer don't work either.
Thanks!
EazGrass
Jan 14, 2014 04:04 PM
cesarnono13
Feb 4, 2011 11:55 PM
kkhakh
Nov 4, 2010 08:38 PM
kkhakh
Nov 3, 2010 02:54 PM
powerboat
Mar 3, 2005 05:13 PM
