1999 A6 Quattro No Start (P1338)
Old Feb 8, 2013 | 05:43 PM
Mike Brown's Avatar
Default 1999 A6 Quattro No Start (P1338)
My nieces share this car and recently it would not start. The initial assumption was that it was the fuel pump, and there is no schraeder valve on the rail to check pressure. I pulled the codes and it came up as P1338 or a bad cam shaft position sensor.
I still wanted to rule out the fuel pump - and disconnected the fuel line at the rail. I don't get any fuel with the key in the "on" position, but it does flow when the engine is cranking (although perhaps not with the pressure I expected).
Would a faulty sensor result in a no start condition? How hard is this to replace? Any advice?
Old Feb 8, 2013 | 10:38 PM
toolagit2qwit's Avatar
could be a bad fuel relay switch itmis located under dash left of steering column
Old Feb 8, 2013 | 10:45 PM
i think the switch # is 372 try limk below for location same on a6
Old Feb 9, 2013 | 07:33 PM
Mike Brown's Avatar
Thanks - I can grab one once we shovel out up here in Maine. Do you suspect the relay because the pump should run in the on position, not just while cranking? I know that is how Volvos are set up.
Old Feb 12, 2013 | 02:38 PM
two fold- your cam sensor is linked to the this switch and switch activates your pump- Did you replace the cam sensor-that could be your problem- either fix is easy and relative inexpensive repair- note: I am from CT 34" of snow I hear you!
jacob190000
May 21, 2015 09:00 PM
lianne_m_jones
Oct 13, 2013 04:46 PM
browny355
Nov 13, 2010 05:55 PM
skoehle1
Jan 29, 2009 10:07 PM
rbl2003
Jun 22, 2008 04:12 PM
