1999 2.8 quattro wont start
Old Jun 17, 2008 | 04:10 PM
rbl2003's Avatar
Default 1999 2.8 quattro wont start
I have a 99 a6 2.8 quattro. occasionally it wont start. wait 4-5 hours then it starts right up. it doesnt turn over or anything. any ideas? thanks
Old Jun 17, 2008 | 04:16 PM
rbl2003's Avatar
Default RE: 1999 2.8 quattro wont start
im sorry it does turn over. but wont start
Old Jun 18, 2008 | 03:46 PM
oc_audica's Avatar
could be a low battery, get it checked and try again.
Old Jun 19, 2008 | 05:24 AM
NH_USA's Avatar
Probably not the battery - If it is raining or damp when it dosen't start I'd change the plug wires. other wise I'd guess that you have a sensor hedding to Mexico.
Old Jun 22, 2008 | 02:35 PM
a6hcw's Avatar
When it does this, try to listen for the fuel pump running for one second at the rear of the vehicle with the key on, but not turned to start. If the fuel pump works, then try replacing the fuel filter. A badly plugged fuel filter may cause starting problems.
Old spark plugs, with too wide a spark plug gap may also cause starting problems.
You should also have you car scanned for free at a local auto store, if you don't have a scanner.
Old Jun 22, 2008 | 04:12 PM
beng's Avatar
ORIGINAL: rbl2003
when it does it not want to start? when the engine all warmed up?
Does it always start when its cold? BENG
hauck7
Jun 12, 2014 12:11 PM
paintballpimp765
Jun 16, 2009 10:33 AM
audi514
May 15, 2009 04:51 PM
audiA63.0
Mar 5, 2009 01:06 AM
