1999 Audi A6 Check Engine Light
Old Mar 24, 2008 | 05:48 PM
umoms's Avatar
Default 1999 Audi A6 Check Engine Light
Hey guys I just recently bought a 1999 Audi A6 with 88k miles and the Check Engine Light came on.
Here are the codes
P017544 Bank 1 LongTerm Fuel Trim
16825 Evap Emission Control System
16839 Evap Emission Control System
17546 Bank 2 Long Term Fuel Trim
60326 Brake Light Switch
The car drives fine. I dont notice anything unusual. Any ideas on these codes?
Old Mar 24, 2008 | 06:14 PM
auditech79's Avatar
Default RE: 1999 Audi A6 Check Engine Light
Both of your EVAP codes need to be addressed for emmisions purposes, the first evap code is stating there is incorrect purge flow. Replace the N80 valve. Thats on top of your airbox, with a single connector and two hoses going into it.
The second EVAP code is saying there is a "gross" leak meaning there is either a huge freaking hole in a line somewhere or your gas cap is bad. Get under the car and look on the passenger's side from the back to the front to see if there is a hole in any of those black plastic evap lines. (NOTE: If you had a tire blow out in the right front it often damages the EVAP lines there)
For the fuel trims, change your air filter and clean your MAF sensor with some electrical contact cleaner then clear the codes and see if it comes back.
The last of course, replace your brake light switch.
Old Apr 25, 2008 | 12:42 PM
umoms's Avatar
I cleared the codes and a day later I get P0455 and P0441.
From what I read its a bad gas cap. But my gas cap seems fine. Any other ideas?
Old Apr 26, 2008 | 03:21 AM
burak's Avatar
Member
i have a very good idea of what it is! you are going to have to buy a part. It is called Evap control module i think but it is under the cover on the passengers side under the hood.! if you have any more quetions let me know
Old May 1, 2008 | 08:07 PM
umoms's Avatar
I tried a gas cap and that didnt fix it. How can I be sure Its the Evap contrule module?
Old Jun 25, 2008 | 11:41 PM
umoms's Avatar
im still stuck with p0441 and p0455.... I checked the things you mentioned and they seem fine....Any other ideas? I have access to a VAG-COM. Can i do anything with that?
Prmovers
Sep 22, 2011 10:58 PM
RomanNY
Apr 24, 2010 10:42 AM
MrTigz5254
Mar 7, 2008 11:56 PM
FixOrRepairDaily
Jul 9, 2007 07:32 PM
