1st AUDI and already starting problems help please!
Old Jun 20, 2008 | 03:19 AM
Asianicestyles's Avatar
Default RE: 1st AUDI and already starting problems help please!
https://www.audiforums.com/m_782913/tm.htm
Look at the 6th post down.
If you need help refer to this
But ignore the pics since it is different vac. lines than yours. I would not recomend putting seafoam through our Crankcase tho. Only engine and fuel tank.
Old Jun 20, 2008 | 03:27 AM
alexfunari's Avatar
and I just pour it in? The second link you gave me was the same.
Should I poor it in slowly? Does it suck? If so should I put it in a water bottle and let it suck slowly?
what about hydrolocking?
Old Jun 20, 2008 | 03:41 AM
https://www.audiforums.com/m_867807/tm.htm
Thats the correct guide. Yes you will let it suck, You should cut up a half water bottle and attatch a hose to the Vac line to make it easier.
The chances of hydrolocking are slim, this will only happen if you let the car suck up too much at one time, in which for the most part the car would simply misfire etc. and just turn off not esseitaly hydrolock.
I did this myself on my car, I attached a rahter long hose from the engine to my lap and held the revs to 2K and let the car suck the seafoam, but not letting it suck up to much at once.
Old Jun 20, 2008 | 08:13 AM
massboykie's Avatar
Member
Hey Asian
What I did when I got my 98 Jetta is give the car a good service. New plugs, belts filters oil etc. This way I figured I knew what was done and when. You might find that clears up the problem. For cleaning the MAF (that someone suggested) get CRC MAF cleaner http://www.vaglinks.com/Docs/Misc/CR...aner_05110.PDF Many places sell it, I bought mine at http://www.Autobarn.com
Here's a "few" more places listed here for parts and stuff http://www.VAGLinks.com
Cheers
Massboykie
gordon85
Jul 30, 2014 03:51 PM
Smokin Tubes
Feb 5, 2012 10:11 AM
smoovmusicdj
Mar 12, 2008 07:13 PM
datdonnguyen
Feb 27, 2008 02:50 PM
hellohellohello
Feb 20, 2007 07:18 PM
