2.7t boosting issue. Not making/holding boost.
Old Aug 1, 2007 | 07:10 PM
ENDEE666's Avatar
Default 2.7t boosting issue. Not making/holding boost.
Just noticed today. Stats on my car are listed in sig below. For some reason, I am not making or holding any boost & the car is not making power. I hear more of an 'air' type sound when I should be boosting. Not like a turbo sound, more like a 'pffffft' like an air hose, but not as loud. I also get a slight surge upon letting off. What is this & how do I fix it? Please ask any additional questions for me to answer & help narrow it down. I am thinking maybe DV's went bad? Please advise what those symptoms would be as well as any other suggestions.
Thanks
Old Aug 1, 2007 | 10:02 PM
alias747's Avatar
Default RE: 2.7t boosting issue. Not making/holding boost.
You have a major boost leak. Make or buy a boost leak tester or take it somewhere to be checked. Since you are APR tuned and it doesn't appear that you have anykind of upgraded DV's or TBB I am guessing you are losing some boost there, I just replaced my stock Dv's a couple days ago after been chipped for 3 weeks and they were torn to shreds, they didnt have any suction at all.
Old Aug 2, 2007 | 12:09 AM
ENDEE666's Avatar
Update! Check Engine Light came on tonight... Hope that helps diagnose. I am going to AutoZone tomorrow for them to read the codes since I dont have a VagCom. Do DVs throw a code? I am pretty sure the TBB does...
Old Aug 2, 2007 | 10:58 AM
ENDEE666's Avatar
Update #2
Had Autozone read the codes & they came up with 2 that both said "Bad MAF reading" so it made me believe the TBB was the culprit since it results in air that was read leaking out. Sure enough, I get home & take it off & have a nice 2" tear... Going to get a replacement one now. Hopefully thats it.
Old Aug 2, 2007 | 05:31 PM
ENDEE666's Avatar
Just finished replacing the TBB, it had TWO 2" tears in it!! Drove for a bit & the light is now off... Thanks for all the help guys!
Old Aug 2, 2007 | 05:54 PM
ppgoal's Avatar
I hope you replaced with a heavy-duty TBB and not an OEM. You should also replace your diverter valves - they're next to fail with the extra boost.
RagtagXMASTER
Jan 12, 2013 01:33 PM
N1a6Germ
Nov 4, 2010 02:35 AM
Seventy7INa45
Dec 17, 2008 07:44 PM
eliTTe
Nov 17, 2007 03:09 PM
hurlyblinkboy
Apr 16, 2007 03:02 PM
