holding boost problem, whats up?
Old Nov 16, 2007 | 11:51 PM
eliTTe's Avatar
Default holding boost problem, whats up?
Is it the cold weather or what? [>:]my car is just not holding the usual 19-20lbs its more like 15lbs. it kind of seems like its because of the cold weather but maybe I'm wrong. I've been thinking about getting a boost controller which should help my problem right? I had a modshack BM but thought it wasn't worth a $hit so I sold it.
Old Nov 17, 2007 | 12:08 AM
cincyTT's Avatar
I'm make believe
Default RE: holding boost problem, whats up?
a mbc will hold boost far better than the n75 can, not to mention reduce lag a bit.
Old Nov 17, 2007 | 09:38 AM
eliTTe's Avatar
yes, I was looking at your pics Nate, is you MBC just hooked up to the 2 hoses that went to the n75? it looks like it but the 180 might be a little different so I wasn't sure.
Old Nov 17, 2007 | 12:01 PM
cincyTT's Avatar
I'm make believe
justpull the lines inthe n75 and install themon the mbc. On mine, the bronze part is the ball&spring and the blue part is the bleed valve.
Old Nov 17, 2007 | 03:09 PM
eliTTe's Avatar
sounds good!
RagtagXMASTER
Jan 12, 2013 01:33 PM
Rachiek
Feb 8, 2008 02:25 PM
ENDEE666
Aug 2, 2007 05:54 PM
hurlyblinkboy
Apr 16, 2007 03:02 PM
kathan21
Oct 1, 2004 09:12 AM
