2.7T bottom end strength
Old Mar 15, 2010 | 04:14 PM
vtraudt's Avatar
Default 2.7T bottom end strength
Still having an A6 2.7T in my cross-hair for turbo upgrade. I was told today that the crank is weak, and anything over a K04 (450 hp at best) may jeopardize the health. Yet, I have seen turbo kits up to 800 hp for the car. What can safely be run on the 2.7T without blowing it apart?
Also: since everything is so tight in the engine bay, even slight issues are supposedly a pain in the butt to fix for the DIYer. Changing turbos requires to take the engine out?
Your comments, please on both items.
Old Mar 16, 2010 | 03:45 PM
ppgoal's Avatar
I cannot respond quantitatively, but given the car is probably over engineered for the stock engine (250-265 hp), it makes sense that it can go stage-1 318hp or even to stage-2 350-450 hp. But be realistic, 800 hp is a lot of power and even if the crankshaft can handle it, the stress it will put on the pistons, valve train, drive train is considerable. I guarantee something will break. Having said that, let's see what the guys with stage-3 upgrades tell you.
Old Mar 16, 2010 | 08:17 PM
jhuffman's Avatar
I just want to make 500 hp with my 2.7t. Do I have to go rs6 turbo for this because k04 really does max out at 450?
Old Mar 17, 2010 | 03:29 PM
ppgoal's Avatar
500 hp is out of my league. Going to K04s, fuel injectors, piggies, and a larger exhaust may be in the cards for me after my K03s go. I figure that will cost $4-5k and give me 400+ hp. I suggest you read up on the AWE and ECS Tuning websites or contact them directly. They make the kits and can advise on what kind of hp gains are possible. I am pretty sure you'll need a tuned chip to take advantage of the mods. Good luck and post your results.
Old Mar 18, 2010 | 11:04 AM
jhuffman's Avatar
That is like a super long term goal. Right now, I just want her to run like she just left the factory again.
GETxSOME
May 9, 2010 09:51 PM
ThePapaCMan
Mar 5, 2007 12:56 PM
Turbo_Snail
Jan 19, 2007 06:03 PM
AudiCross
Oct 7, 2006 06:21 AM
audihopeful
Mar 28, 2006 05:43 PM
