2.7t ESP light automatacally turns on.
it turns on and i cannot turn it off no matter how many times i press the esp button. it turns on while normal driving sometimes. it once came on while the car was on the ON position but not idling and wouldnt turn off. any ideas?
No the abs light is not on. just out of normal driving the light turns on and stays until the car is turned off and on again.
Buy CRC MAF sensor cleaner from auto part store to clean the MAF wire and see what happen. Did you switch to K&N filter lately? Maybe too much oil fouls the MAF and trigger this light.
Also you can vag-com and see any code stored even no CEL.
Options: Brake Light sensor on wheels, battery about to go dead.
Also when the light comes on again, ask some one to see if you get brake lights on when brake pedal is pressed. If it is not ON then it is brake pedal light switch.
