2.7t ESP light automatacally turns on.
Old Jul 17, 2011 | 06:00 PM
budhani786's Avatar
Default 2.7t ESP light automatacally turns on.
it turns on and i cannot turn it off no matter how many times i press the esp button. it turns on while normal driving sometimes. it once came on while the car was on the ON position but not idling and wouldnt turn off. any ideas?
Old Jul 19, 2011 | 06:59 AM
bigdadi's Avatar
Is the ABS light also ON? If it is, likely the brake pedal light switch problem. Cost 12.00 at dealer.
Old Jul 19, 2011 | 10:17 AM
budhani786's Avatar
No the abs light is not on. just out of normal driving the light turns on and stays until the car is turned off and on again.
Old Jul 19, 2011 | 11:35 AM
bigdadi's Avatar
Default MAF sensor may be the problem
Buy CRC MAF sensor cleaner from auto part store to clean the MAF wire and see what happen. Did you switch to K&N filter lately? Maybe too much oil fouls the MAF and trigger this light.
Also you can vag-com and see any code stored even no CEL.
Options: Brake Light sensor on wheels, battery about to go dead.
Also when the light comes on again, ask some one to see if you get brake lights on when brake pedal is pressed. If it is not ON then it is brake pedal light switch.
Old Jul 19, 2011 | 05:57 PM
budhani786's Avatar
i haven't changed the air filter at all. i have completely forgotten about it. It can cause the esp light to go off?
Old Jul 19, 2011 | 06:10 PM
hxgaser's Avatar
Only sure way to tell is to hook it up to a scanner and see what the code points you to. Otherwise, I would first check the brake fluid level and see if it is topped off.
ramon_lopez50
Sep 21, 2013 08:04 PM
1280bluehills
Feb 17, 2011 08:42 PM
themoleman
Oct 30, 2010 04:29 AM
xxramezyxx
Mar 24, 2009 12:03 PM
turbolove
Feb 18, 2009 02:34 AM
