2.7T Fluid Leak
Old May 9, 2009 | 11:30 PM
thecollegestudent's Avatar
Default 2.7T Fluid Leak
So the other day as I came back from class I noticed that I had a clear fluid leaking from the underside of my car. It's clear and slightly oily. Its coming from my passenger side of my car. It's not by my wheels nor is it by my brake pedal which I have been told are problematic areas for a brake fluid leak. Can anyone tell me what this might be? Brake fluid, power steering...?
Old May 10, 2009 | 09:51 AM
TwinTurboC5's Avatar
Default Fluid Leak
Hi to TheCollegeStudent,
The fluid you're describing is possibly gear oil leaking from your your transfer case. The Quattro A6 models all have this similar problem and its very common. If you're able to look under your car, you need to visiually inspect it for any wet areas on the underside of the drivetrain. If it is coming from the transfer case its most likely leaking from the rear seal. If so it wil be noticeably wet where the driveshaft exists from the rear of the transfer case. The seal itself is not very expensive, usually less than $20, but if you're not mechanically inclined, you will pay for several hours of labor to have it replaced. Good Luck with it!
Greg23
Apr 16, 2014 04:09 PM
etyrol
Aug 26, 2013 10:24 PM
vtraudt
Feb 25, 2012 11:09 AM
meta4
Sep 26, 2006 09:34 PM
budnfrida
Jul 5, 2006 06:04 PM
