2.8l A6 CAI
People are reporting the same gains, if not more by doing the "Darintake". It's free if you just use your stock filter.
Here is a link, along with dynos..
You don't want an aftermarket intake, this mod will still give you that VROOOOM noise with a noticable difference. Audi intakes are the only thing done right, I swear, they are good up to 300+HP. Look at stage 3 and 3.5's on audiforums or audiworld, they are running the darintake.
http://forums.audiworld.com/s4/msgs/1189646.phtml
http://forums.audiworld.com/s4/msgs/1182984.phtml
I have a K&N drop in, so your sayin that if I cut a hole in the bottom of my air box, and put some mesh on it, I will hear some nice intake growl as if I had a reg cone filter? If so, I would prefer this cause I do like the clean look of the stock air box.
on my car where was the circle inside the air box i remove it and i run an 3 inch rubber house with an funnel (painted black)at the end coming from front lower pass side so that gives me more cold air, but when enter in the air box i face it to the side , just for rainy days, also i have drop in k&n. all set up is still project i didn`t secure the air box because i have the house run inside, i plan run another hose and this time i will drill a hole for it, and also will get the air from pass fender. the original air tube is still connected. if you search a little more on vortex or some vw forum is an tutorial, i guess look for cold air intake.
