200 a6 abs and brake come on and off
Old Nov 10, 2006 | 12:29 PM
charlied's Avatar
Default 200 a6 abs and brake come on and off
2000 A6 The ABS light and the brake comme on then go off
What to do
Old Nov 11, 2006 | 12:30 AM
mikeko's Avatar
Default RE: 200 a6 abs and brake come on and off
If you search ABS, you will see whole lot of info on this. If you have 3 beeps and your ABS lights comes on with break light blinking, than you may have bad ABS module. I sent in my Module to get it re-built and it works great!! It cost $200 which includes UPS both way shipping. Dealer will charge you any where between $1500 to $2000. Here is the link to BBS http://cgi.ebay.com/ebaymotors/VW-Pa...mZ230040850628
ModuleMaster Removal Video
Old Nov 11, 2006 | 12:31 AM
mikeko's Avatar
Here is the ABS removal video link http://www.modulemaster.com/audiabsremoval.html
Old Feb 13, 2007 | 04:07 AM
skyz's Avatar
hi mike, if i bring the car to brake check or any car shop? would they fix that problem??
or the best way is to relace the ABS module?
thanks alot!
Old Feb 21, 2007 | 01:41 AM
skyz's Avatar
is it ok if i still keep driving without fixing it??
how bad would it go?
thanks a lot
Old Feb 22, 2007 | 11:36 PM
twinturbomew's Avatar
you can drive for as long as you wish on a bad abs unit. you abs system will not work but it dose not effect the car. the breaking system still works. but the breaks tend togo on hader in the read. The S4 guys used to dissconect there abs mods at the track. a shop might not know exactly how to do the removal. you can do it your self it is quite easy.
1 remove driver side tire
2 remove inner frnder liner
3 remove washer resivware
4 you should now have axsess to the modual there are 4 or 5 t15 bolts holding it in
Old Feb 22, 2007 | 11:52 PM
Ozz's Avatar
Ozz
I had the same affair on one of my previous cars - check for the sensors on the brakes.Sensor is not expensive at all.
abc27
Aug 25, 2013 04:19 PM
NorthernComfort
Sep 19, 2007 07:54 AM
